Steering column rebuild, where is the article?
https://slantsix.org/forum/viewtopic.php?t=47181
Author:  pishta [ Fri Dec 02, 2011 5:05 pm ]
Post subject:  Steering column rebuild, where is the article?
I saw a post or article here that showed what bearings to buy at Granger or Fastenal to make a lower ball bearing support for a '65 column, but I cant find it anywhere. Im putting my column back together but I cant figure out what the 2 square headed bolts hold on. They seem to just pass though the cast bearing support and get a castlelated nut? Or am I missing a plate or part?
Author:  SlantSixDan [ Fri Dec 02, 2011 8:00 pm ]
You can't find it 'cause it's not here. It's on FABO.
(Send me a PM if you need an OE-quality new turn signal switch for your column rebuild)
Author:  pishta [ Sat Dec 03, 2011 9:27 am ]
Thanks Dan. Helps if I spelled it right!
