It is currently Sat Dec 27, 2025 3:26 pm
 Post subject: Head squirting coolant
PostPosted: Sat Dec 10, 2011 1:38 pm
Hello men
I was removing the intake/exhaust manifold from my 83 B150 van.
I got to the fourth or fith nut from the flywheel when coolant sqirted out all over the place. I think its a cracked water jacket??
83 B150 /6 4spd
97 JeepWrangler Sport 4.0
2001 VW Beetle TDI 5sp
2000 Nissan Xterra
73 Dodge B300 van
PostPosted: Sat Dec 10, 2011 1:52 pm
Sounds to me as if one of the manifold studs backed out with the nut you were removing. Some or all of those stud holes (depending on head casting) back up onto water passages.
PostPosted: Sat Dec 10, 2011 2:24 pm
Thanks for the reply slant six Dan
That makes sense. I have had this van for about 5 years and I have just started to learn more about her, meaning she is at the end of her wear cycle and its time to rebuild her!
So when I get the manifolds off should I use a little blue locktite on the studs that came out?
Is there a stainless stud/bolt kit available? Thanks
83 B150 /6 4spd
2000 Nissan Xterra
73 Dodge B300 van
Users browsing this forum: Ahrefs [Bot] and 12 guests
