It is currently Mon Jun 22, 2026 11:04 am
Turbo Donor or maker
Garret 0%  0%  [ 0 ]
Majestic Turbo-Waco 100%  100%  [ 1 ]
Total votes: 1
 Post subject: Slant 6 Engine Sim
PostPosted: Tue Dec 13, 2011 12:34 pm
#1- Has anyone found a specific engine sim program that contains all accurate Slant 6 specs? If so what & where?
#2- Has anyone have proven suggestions for Turbo application(makers or Donors) i've done some research as to donors. The turbo itself(not Plumbing or acaccesoriesSo Far Garret seems to be my best bet?
#3-RE:Slant 6 Convert by Bob Dibiase- HAs anyone figured that requirement for MAF Sensor on a Turbo system and the donor required?
Thanks, To all Dodge Nuts.
 Post subject: Not exactly...
PostPosted: Tue Dec 13, 2011 7:39 pm
Nope, they cater to the usual 8 cylinder crowd...but, you can fill in the flow chart with values others have posted on stock and not stock heads to make an 'educated' guess. Most of the other variables like compression and cam timing work OK. Using the boost values will also be kind of a shot in the dark. Intake manifold choices on something like Desktop Dyno also are somewhat problematic as they lean more toward the V-8 'crab' model...even selecting a TPI manifold model to simulate the clifford cast narrow port hyperpak comes out in lower numbers than what the real world drag numbers say.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 3 guests
