Band adjustment Specifications
https://slantsix.org/forum/viewtopic.php?t=47323
Author:  ceej [ Sun Dec 18, 2011 3:46 pm ]
Post subject:  Band adjustment Specifications
The following information is for use with unmodified A904 and A727 Transmissions. If lever ratios have been changed, consult a transmission specialist before using this band adjustment information.
To include your model year information, please forward to Ceej or another Moderator via PM.
Torque*
1962-1963 Torque to 72 inch pounds (unless you have the c-3705 adapter)
1971-1973 Torque to 72 in-lbs
1974-1983 Torque to 41 in-lbs
1984 and later Torque to 72 in-lbs
Number of turns to back adjuster off
Kickdown Band
A904
1962-1963 170 2-5/8 turns (Lock 20 ft-lb)
1962-1963 225 2 Turns (Lock 20 ft-lb)
1971-1979 2 Turns
1980 on 2-1/2 Turns
A727
1971-1978 440 Dual Exhaust 2 Turns
All others 2-1/2 Turns
Low Reverse Band
A904
Slant Six engine
1962-1963 5-1/4 Turns
1971-1973 3-1/4 Turns
1974-1983 7 Turns
1984 on 4 Turns
V8 All 4 Turns
A727
All models 2 Turns
*Note: For Kickdown and Low-Reverse Band
