| wheel cylinder replacement https://slantsix.org/forum/viewtopic.php?t=4736 |
| Author: | Duster Driver [ Wed Jan 01, 2003 11:08 pm ] |
| Post subject: | wheel cylinder replacement |
My left rear wheel cylinder is leaking fluid and needs to be replaced. Can the wheel cylinder be replaced without having to take off the brake shoe? In the manual that I have it talks about different special tools that are used to remove the brake shoe. Do you really need these special tools? |
| Author: | alienduster [ Sat Jan 04, 2003 10:33 pm ] |
Kinda yes, kinda no. You definitely have to remove the uppoer springs and spring/pivot pin in the middle of each shoe. you can then leave them hanging there and will have anough room at the top to remove the cylinder. |
| Author: | Matt Cramer [ Mon Jan 06, 2003 4:58 pm ] |
| Post subject: | Special tools? |
What special tools? |
| Author: | Plymouth Duster72 [ Wed Feb 05, 2003 5:02 pm ] |
No special tools required...granted, it may be easier with the proper tools but you can remove the shoes with simple hand tools from around the house. -Don |
| Author: | dgc333 [ Thu Feb 06, 2003 4:28 am ] |
You can purchase the proper brake pliers for around $10 and another 3 or 4 for the cup tool. For the number of times you will do brake jobs paying for a Snap-On set is just not warranted. The pliers especailly make the job so much easier I would consider it a mandatory tool in your box. |
