| Lower Ball Joint, 61-62 vs later 63 on up https://slantsix.org/forum/viewtopic.php?t=47381 |
| Author: | dart4forte [ Tue Dec 27, 2011 3:43 pm ] |
| Post subject: | Lower Ball Joint, 61-62 vs later 63 on up |
Can someone tell me the difference in ball joints from 61-62 lower ball joint from the 63 on up ball joint? I have a pair of the early ball joints however they don't seem to be the same as the later ball joints. |
| Author: | SlantSixDan [ Tue Dec 27, 2011 4:49 pm ] |
'60-'61 vs. '62-'72 is the interchange grouping. |
| Author: | dart4forte [ Tue Dec 27, 2011 6:21 pm ] |
So what's the differance? Earlier are rebuildable. The two NOS ball joints I have don't appear the same as the later ball joints. The later joints are more of a interfearance fit while the earlier ball joints I have appear to be loose. |
| Author: | senginc [ Sun Jan 01, 2012 8:12 pm ] |
| Post subject: | Re: Lower Ball Joint, 61-62 vs later 63 on up |
Quote: Can someone tell me the difference in ball joints from 61-62 lower ball joint from the 63 on up ball joint? I have a pair of the early ball joints however they don't seem to be the same as the later ball joints.
Do you have 61/62 lowers? I may need a set.
| Author: | VDART [ Mon Jan 02, 2012 6:07 am ] |
60 & 61 lowers were similar to the uppers(threaded single unit), the replacement ball joint threaded into the arm, later 62 & up they made the lower ball joint assembly . |
| Author: | senginc [ Mon Jan 02, 2012 8:24 am ] |
Quote: 60 & 61 lowers were similar to the uppers(threaded single unit), the replacement ball joint threaded into the arm, later 62 & up they made the lower ball joint assembly .
Does that mean the uppers will fit?
| Author: | dart4forte [ Mon Jan 02, 2012 9:13 am ] |
I have the 61 lowers |
