Stromberg MPG Report
https://slantsix.org/forum/viewtopic.php?t=47391
Author:  61 V200 [ Wed Dec 28, 2011 3:38 pm ]
Post subject:  Stromberg MPG Report
First fuel "fill" since I converted over to the WW3-275 carb and Dutra duals with 2 1/4" plumbing
I calculate 15 MPG after burning 8.875 gallons.
Keep in mind I always have my foot on it. :D That will pass
Maybe see what.. :?:... 17.. :?: ....with a lighter touch.
Author:  raPoM [ Wed Dec 28, 2011 4:27 pm ]
What gears and transmission do you have? Is that city or highway or mixed?
Author:  61 V200 [ Wed Dec 28, 2011 5:05 pm ]
904 auto and I'm assuming stock (3.23) rear end. (Someone will correct me here if I am wrong about that)
Guess I should spend some time to calculate it at some point to be sure.
City and highway. Can't keep it under 70-75 on the freeway. That too will pass.
Again, I've had a heavy foot since the conversion.
Author:  Sam Powell [ Wed Dec 28, 2011 7:49 pm ]
That is what my Stromberg did exactly. It did give it more power. I went back to the BBD which gave me 22 MPG all the time. The car was my daily driver at the time, and I put tons of miles on it, so it was important to get that 50% improvement. But, the Stromberg made it feel like a V-8.
Have you recurved your distributor at all. If not, I think if you play with your timing curve you might do better. Take a look at Aggressive Ted's set up under the FAQ thread of the Engine section.
Sam
