It is currently Tue Jun 16, 2026 6:28 am
 Post subject: Rear End
PostPosted: Tue Dec 31, 2002 12:55 am
I have got a line on an 8 3/4in rear end out of a 60s Dart. Not sure the details on the Dart. Is it a conversion that would work for my 74 Duster? What would be the advantages/disadvantages? Is there anything in specific that I should look for on this unit, numbers,etc? Thank you so much for the help.
PostPosted: Tue Dec 31, 2002 8:28 am
Does this unit have big nuts holding the brake drums on?
How wide is it?
 Post subject: Bolt pattern
PostPosted: Tue Dec 31, 2002 10:14 pm
All A-body 8 3/4" rears came with the small bolt pattern from the factory. I believe your Duster uses the large bolt pattern. You'll also have to watch out for the driveshaft - it'll probably have to be shortened.
The 8 3/4" unit is tougher, but I'm not sure a slant car needs the extra toughness, and you may not need the extra weight either. I seem to remember hearing the 8 1/4" one is good for up to 300 hp. Unless you're running a turbo, nitrous, or supercharging (or planning a V8 swap), the 8 3/4" may be overkill. Not that that's necessarily a bad thing.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Jan 01, 2003 8:49 am
two big advantages to the 8 3/4 are ease of gear changes and the fact the axles are retained out at the hubs rather than with c-clips in the differential. the clips, by the way take most of the load around a corner. i have had no troubles from mine, but the possibility is there. but, like matt said, unless you're making a lot of power or are serious about racing the heavier rear may not be worth it.
-james
PostPosted: Wed Jan 01, 2003 9:24 am
Is the '74 a drum or disc brake car? If it's a drum it will have the small bolt axles anyway and that will make the swap a lot easier. Driveshaft has to be shortened about 1-3/4". Most A-body 8-3/4's had the small u-joint in them too.:)
