| Cast Crank K1 KB Build https://slantsix.org/forum/viewtopic.php?t=47406 |
Page 1 of 2 |
| Author: | DadTruck [ Fri Dec 30, 2011 7:19 am ] |
nice photos, please post on your progress * what valves do you plan to use, have you flowed them and the ported head? ** what did you do on the oil pump,, guessing that you are using the plastic tube to show the trajectory of the oil spray? *** have you picked a cam? thanks DT |
| Author: | Rug_Trucker [ Fri Dec 30, 2011 9:40 am ] |
What year head? Those chambers look nice. I have always made the flow from the plug towards the exhaust. I think I got that idea from a porting book. |
| Author: | Dart270 [ Fri Dec 30, 2011 2:45 pm ] |
Looks like wonderful work. You might beat me to press with that cast/K1 motor. Mine has been on the stand assembled for 1yr, and finally getting top end on it now... Lou |
| Author: | Supercharged SL6 [ Fri Dec 30, 2011 4:34 pm ] |
Using 1.70 1.44 stainless valves. didn't have head flowed basicly ported out bowl area to match valves polished rest of port. I think its a early 70s head. Using Comp 264 cam with 1.6 rockers giving about .475 lift. Oil pump mod I found somewhere on this site, can find site if you want. Used dremel to open up pocket under rotors then drilled hole through body exiting at gear. I used aluminum pump for ease of drilling. Motor was run about 3500 miles this past summer |
| Author: | Dart270 [ Fri Dec 30, 2011 6:32 pm ] |
Looked at all your pics and am even more impressed. My guess is you will be disappointed with less than 350 HP. Your attention to detail is fantastic. What were your results from last summer w/carb? Wanna come to a Slant 6 race?? Best wishes, Lou |
| Author: | DadTruck [ Sat Dec 31, 2011 10:46 am ] |
I had seen the post on that oil pump mod,, just wanting to confirm that's what was going on there.. I noticed the large radius's at the 90 degree cuts on the windage tray flaps,, nice way to distribute stress and eliminate cracks,,good idea |
| Author: | slantzilla [ Sun Jan 01, 2012 6:16 am ] |
Very nice looking project there. Was any of the rest of either land crushed in? How much gap were you running? KB's do need a lot of gap, especially in a boosted situation. Trust me, I broke one in half with spray. |
| Author: | Supercharged SL6 [ Sun Jan 01, 2012 4:13 pm ] |
Just broke top part of land seen in pic. It is really thin there from valve pocket, I was running .035 gap, it definitely looks like the rings butted cyls had little scoring top of travel, #6 cleaned up #1 couldn't get em all out, opened up gap to .055 |
| Author: | stop the beast [ Tue Jan 03, 2012 6:12 pm ] |
| Post subject: | Re: Cast Crank K1 KB Build |
Are those the +5cc KBs? What's your tartget compression ratio? I was considering using the +18cc KBs for a turbo setup. |
| Author: | Supercharged SL6 [ Tue Jan 03, 2012 7:51 pm ] |
Yes I have KB 239 they end up .010 below my stock deck, the head is 59cc with a felpro gasket I have 9.8 static compression, the dynamic compression is 8.2 and that is what really matters. With a centrifugal style super charger like my paxton it only goes into boost when you floor it hard so 95% of the time the pressure is being blown off, it has air blowing through the intake manifold all the time, that helps scavenge the cylinder but there is no boost untill vacumm drops to 0 under 5 lbs of boost my DCR gos I think to around 11.0. With a turbo I think the compression would be to high I believe a turbo runs hotter and i'm not sure how the boost comes in |
| Author: | stop the beast [ Wed Jan 04, 2012 9:25 am ] |
Quote: Yes I have KB 239 they end up .010 below my stock deck, the head is 59cc with a felpro gasket I have 9.8 static compression, the dynamic compression is 8.2 and that is what really matters. With a centrifugal style super charger like my paxton it only goes into boost when you floor it hard so 95% of the time the pressure is being blown off, it has air blowing through the intake manifold all the time, that helps scavenge the cylinder but there is no boost untill vacumm drops to 0 under 5 lbs of boost my DCR gos I think to around 11.0. With a turbo I think the compression would be to high I believe a turbo runs hotter and i'm not sure how the boost comes in
I think the turbo and centrifugal super charger are going to respond somewhat similar. At least with MPFI and a good tune and an intercooler.So, how much boost have you thrown at the KB pistons? Were you running stock rods with them at any time? The engine is looking excellent! |
| Author: | Supercharged SL6 [ Wed Jan 04, 2012 5:27 pm ] |
Just 5 LB, the KB pistons would only work with the K1 rods in a cast crank motor, a forged crank motor you could use stock 198 rods if you can find some. The carbureted motor I ran had stock pistons & rods I ran 5LB on that motor also, that motor had a vibration, I though it was in the drive line but its gone in the KB K1 motor |
| Author: | Dart270 [ Wed Jan 04, 2012 5:47 pm ] |
5 lb is not that much boost. You should not break anything with that unless the tuneup is way off. I am looking forward to testing the new meth/H2O injection and 3" exhaust with the '68 Dart, once I fixed the busted converter... Full runs with 11 psi will be pretty wild. Lou |
| Page 1 of 2 | All times are UTC-07:00 |
