| Slant Six Carter Carb Question ... https://slantsix.org/forum/viewtopic.php?t=47454 |
Page 1 of 3 |
| Author: | Valiant ´75 (DK) [ Wed Jan 04, 2012 3:21 am ] |
| Post subject: | Slant Six Carter Carb Question ... |
Hey. I just got this Plymouth Valiant ´75 and it´s my first american car I have read a lot on this page about the engine but can´t seem to id it. The carb is a 2bbl Carter 2681 i belive ... (pic.) The engine is from a Plymouth Volare from 81´, i been told. The engine sounds very good but the carb is the problem! The question is would the weber 38/38 be any good for my engine? Have read and lot about the 32/36 is to small for the 225. Hope you understand it all PS. Thanks for this page - is gold !!! https://picasaweb.google.com/1093386251 ... 3/SlantSix Hope the link works ... |
| Author: | exoJjL [ Wed Jan 04, 2012 4:13 am ] |
If you have a pic that would help but i'm fairly certain the carb is a Carter BBD. If you have problems with it; probably because of the throttle shaft bushings. I've heard good things about Webers, never used one myself. |
| Author: | /'d Box [ Wed Jan 04, 2012 5:46 am ] |
Welcome. Regarding the Webers, I have run both the 38 and the 32/36 on my van and I prefer the 32/36 for my intended use. in the past, I have also run the 32/36 on a Volare with good results. Adapting the Weber requires some cost and/or some fabrication though. Good luck with your slant. |
| Author: | Valiant ´75 (DK) [ Wed Jan 04, 2012 6:55 am ] |
Quote: Welcome. Regarding the Webers, I have run both the 38 and the 32/36 on my van and I prefer the 32/36 for my intended use. in the past, I have also run the 32/36 on a Volare with good results. Adapting the Weber requires some cost and/or some fabrication though. Good luck with your slant.
Ok sounds good but can the 38 work on my 225? Don´t mind the work fitting the weber but where too buy one that fits? Can this one my car ? http://www.ebay.com/itm/300206316037?_t ... IT&vxp=mtr Maybe somebody got a used complete set weber/holley? Thanks for the welcome |
| Author: | Valiant ´75 (DK) [ Wed Jan 04, 2012 6:57 am ] |
Quote: If you have a pic that would help but i'm fairly certain the carb is a
Carter BBD. If you have problems with it; probably because of the throttle shaft bushings. I've heard good things about Webers, never used one myself. There is a link to some engine/carb pic. |
| Author: | /'d Box [ Wed Jan 04, 2012 7:42 am ] |
The 38 will work fine. As I recall, I needed to buy adapters for the manifold, a trans kickdown cable, fabricated a linkage bracket, etc. Here are some links that might be helpful. I've purchased from both. http://www.redlineweber.com/ http://www.webercarbsdirect.com/ |
| Author: | Rug_Trucker [ Wed Jan 04, 2012 2:36 pm ] |
The 2681 is not the carb model number. Only way to indentify that is by a metal tag. I doesn't look like a super six carb. I think it is off a 318 V8. The slant units will have a bent PCV tube for the PCV hose. V8's are straight. The flat spot at the top of the choke is thinner looking on a V8 BBD. Watch the BBD video that is available via this web site. |
| Author: | nuttyprof [ Wed Jan 04, 2012 3:56 pm ] |
"I just got this Plymouth Valiant ´75 and it´s my first american car" Laughing "I have read a lot on this page about the engine but can´t seem to id it." Should be a forged crank 225. |
| Author: | exoJjL [ Wed Jan 04, 2012 4:53 pm ] |
Quote: The 2681 is not the carb model number. Only way to indentify that is by a metal tag.
The V8 BBD should also have a couple holes in the throttle plate that the sl6 BBD don't have. The V8's need more air for idle than the /6. From what I know about this sl6's either run fine or horrible due to these holes.
| Author: | WagonsRcool [ Wed Jan 04, 2012 7:56 pm ] |
Valiant 75's carter BBD looks to have the bent PCV nipple, so I think it used to be a super6 carb- before it got hacked. That choke cable setup is just FUGLY! It would have taken alot less work to just fix it properly. And why is there a vac hose going from the manifold port on #6 intake runner then Tee'ed into the vac advance hose? |
| Author: | exoJjL [ Thu Jan 05, 2012 4:10 am ] |
Quote: bent PCV nipple, so I think it used to be a super6 carb- before it got hacked.
That's funny, it don't don;t look hacked, at least you can't see from the complete opposite side of the engine in the pictures.
Quote: That choke cable setup is just FUGLY! It would have taken alot less work to just fix it properly.
here...click me
| Author: | Rug_Trucker [ Thu Jan 05, 2012 5:04 am ] |
[quote="exoJjL".[/quote] The V8 BBD should also have a couple holes in the throttle plate that the sl6 BBD don't have. The V8's need more air for idle than the /6. From what I know about this sl6's either run fine or horrible due to these holes.[/quote] I wouldn't bet the farm on the holes comment. Where the idle screws are in the base things are different. More restriction on the slants. 2 square holes. |
| Author: | Valiant ´75 (DK) [ Thu Jan 05, 2012 5:23 am ] |
Quote: "I just got this Plymouth Valiant ´75 and it´s my first american car" Laughing
Why Laughing ???? Iám danish "I have read a lot on this page about the engine but can´t seem to id it." Should be a forged crank 225. I have had about 40 European cars and this is my first american car. Almost all other dane that is driving american has a V8 but I like the slant six Can anybody tell me anything about the engine? What carb should I juse on my car? Weber or Holley? The Carter is garbage and it will be changed. I don´t know who fixed the carter on the car but I want a new one |
| Author: | exoJjL [ Thu Jan 05, 2012 5:25 am ] |
Quote: [quote="exoJjL".
The V8 BBD should also have a couple holes in the throttle plate that the sl6 BBD don't have. The V8's need more air for idle than the /6. From what I know about this sl6's either run fine or horrible due to these holes.[/quote]I wouldn't bet the farm on the holes comment. Where the idle screws are in the base things are different. More restriction on the slants. 2 square holes.[/quote] I have no problem with citing a source: http://www.slantsix.org/articles/supersix/article.htm I am also running a sl6 BBD over earlier V8 BBD for prescribed reason. So how about that farm? |
| Author: | Valiant ´75 (DK) [ Thu Jan 05, 2012 5:46 am ] |
Quote: Valiant 75's carter BBD looks to have the bent PCV nipple, so I think it used to be a super6 carb- before it got hacked. That choke cable setup is just FUGLY! It would have taken alot less work to just fix it properly.
Do know anything about the vac hose setup. I got the car one week ago and it does not run quite well. That´s why I want a new carb but maybe there is something else wrong ??
| Page 1 of 3 | All times are UTC-07:00 |
