It is currently Sun Jun 14, 2026 12:47 am
PostPosted: Tue Jan 10, 2012 3:39 am
Can anyone please tell the maker and part number of a 1BBL intake to 2BBL super six carburetor my 1BBL is junk and i have a good Super six carb i would like to mount to my truck oh 86 d150 a833 trans thank you for any help you can give me
PostPosted: Tue Jan 10, 2012 5:04 am
I am not aware of such adapter but you can modify your 1bbl intake to mount that 2bbl carb.
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Tue Jan 10, 2012 9:08 am
There are several companies that sell a one to two barrel carb adapter, but it is generally not a good idea to use one. The one barrel intake opening is a choke point for air flow so you will not get the full benefit of the two barrel carb. Further, you may or may not have hood clearance issues depending on your vehicle and air cleaner.
Buy one HERE
PostPosted: Tue Jan 10, 2012 3:45 pm
Don't use an adaptor to mount a 2bbl carb on a 1bbl intake. It won't work right, the hookup hassles will be large, and it's generally just a waste of money, time, and effort. Get a 2bbl intake (or make one, see the parallel 2bbl setup article. Photo documentation of a very well done such conversion is here).
PostPosted: Tue Jan 10, 2012 7:51 pm
ok i knew it would be restrictive to put the 2BBL on my intake i might just have to buy a reman 1BBL or find a used super six intake thanks for all your help
PostPosted: Wed Jan 11, 2012 12:19 pm
Yeah you might as well do it the right way the first time. Otherwise you're just going to end up doing it twice.
I'm sure you're fine being in Texas but I'd check the emissions laws before doing anything. If everything is clear, the cheapest route is to see if anyone here has a non reman Holley 1945 you can swap onto there. If you don't find any luck there, then you can find yourself a super six setup for fairly cheap since you don't need the kickdown due to the 4spd trans.
Users browsing this forum: Ahrefs [Bot] and 14 guests
