| Ever see this ?? https://slantsix.org/forum/viewtopic.php?t=47489 |
Page 1 of 2 |
| Author: | Fopar [ Sat Jan 07, 2012 11:15 am ] |
| Post subject: | Ever see this ?? |
Checked compression on motor in the Dart to see what was going on with #2 cylinder not firing. 5# on number 2 with 160# on all the rest, so pulled valve cover and found #2 intake pushrod out of place. After pulling push rod out found this. ![]() ![]() Richard |
| Author: | kielbasa [ Sat Jan 07, 2012 11:44 am ] |
Hollow point. |
| Author: | Joshie225 [ Sat Jan 07, 2012 11:57 am ] |
That's a new one for me. What brand pushrods? |
| Author: | Fopar [ Sat Jan 07, 2012 12:36 pm ] |
I don't remember what brand they have been in since I built the motor. Richard |
| Author: | sandy in BC [ Sat Jan 07, 2012 1:09 pm ] |
That, my friend, is a Chev Trick. Roller cam SBC with the self aligning rockers do that fairly often. I have prolly had 10 of those over that last Kabillion miles. Easy fix ....... The Chevs also wear holes right through the rocker....something a slant is less likely to do. <MEH>! |
| Author: | Fopar [ Sat Jan 07, 2012 1:51 pm ] |
Josh they were Seal Power push rods. Sandy this is not a roller cam engine and not a lot of spring pressure. Richard |
| Author: | raPoM [ Sat Jan 07, 2012 2:04 pm ] |
| Author: | sandy in BC [ Sat Jan 07, 2012 2:25 pm ] |
The roller sbc dont use a lot of spring pressure,,,,,its about something else. Its prolly just defective manufacture. I just replace and forget (not so difficult anymore) |
| Author: | Fopar [ Sat Jan 07, 2012 2:29 pm ] |
Yes upon looking at the ball, it looks like it didn't get welded on real good and the valve lash let the push rod hammer on the ball till it split the hollow rod. Richard |
| Author: | sandy in BC [ Sat Jan 07, 2012 2:31 pm ] |
Welcome to the Chevvification of replacement parts! |
| Author: | sandy in BC [ Sat Jan 07, 2012 2:36 pm ] |
Seriously though.... I think the pushrod end manufacturing is suspect....thats where it starts on the sbc.....if they dont do what yours did , they abrade the stamped rocker till it pokes through the rocker. You lose a lot of lift and duration that way. No damge however. I drove 600 miles with an intake rocker like that in sept. ... .. .. You will forget all about it 1 week after replacement. |
| Author: | hantayo13 [ Sat Jan 07, 2012 3:15 pm ] |
hhhuuummmmm mushroom pushrods????? |
| Author: | sandy in BC [ Sat Jan 07, 2012 3:17 pm ] |
pushrod mushrooms changed the way I looked at life...... .....now I just dont look...... <frontside 540 rodeo....Blind> |
| Author: | SlantSixDan [ Sat Jan 07, 2012 4:06 pm ] |
Quote: Welcome to the Chevvification of replacement parts!
You misspelled Chery, which itself is a deliberately misspelled camp-on of "Chevy", and it's not the only copycat game they play.
| Author: | SlantSixDan [ Sat Jan 07, 2012 4:08 pm ] |
Quote: pushrod mushrooms changed the way I looked at life......
Quote: .....now I just dont look......
| Page 1 of 2 | All times are UTC-07:00 |
