It is currently Tue Jun 16, 2026 10:35 am
PostPosted: Fri Jan 06, 2012 11:55 pm
Ok I've been doing much research,and find conflicting info regarding my question:
I have an 87 D100 with the stock hydro engine. I want to pick up a head and start porting it and get it machined so I can do a weekend swap,and not have much down time. I would like to use an older "drool tube" head for better spark plug selection,but I want to keep the hydro rockers/cam/lifters.
Is this an issue? I know that my current head uses a steeped bolt for the rocker shaft vs. the early head not using a stepped bolt. From what I have read in my research,the reason for the stepped bolt was to keep the rocker shaft from being installed incorrectly. Is this going to be an issue for me? Will I be able to use the DT head with all of the hydro gear from my motor?
I appreciate any input you may have.
Jared
PS- thank you Reed for this http://www.slantsix.org/forum/viewtopic ... head+hydro lots of good info. :D
PostPosted: Sat Jan 07, 2012 12:05 am
Yes, you can put everything on the earlier head if you drill out the rear hole on the bottom of the rocker shaft.
PostPosted: Sat Jan 07, 2012 12:18 am
Cool,thank you Josh. :D
PostPosted: Sat Jan 07, 2012 7:41 am
Let me know if you ever want to sell that 87 head and/or engine.
PostPosted: Sat Jan 07, 2012 1:22 pm
Will do Lou :D What are your plans?
PostPosted: Sun Jan 08, 2012 7:15 am
There is a decent chance I'll be driving west this spring/summer and could pick up. No firm plans at the moment...
PostPosted: Sun Jan 08, 2012 10:32 am
That would be great! I have always wanted to meet you,if it does happen it would be cool to hang out for a minute. I should have my new head done,and swapped by then too,so the hydro head should be available.If you make it out,you can have it.
Jared :D
PostPosted: Mon Jan 09, 2012 5:09 am
Thanks, Jared. I'll keep this visit in mind...
