It is currently Mon Oct 12, 2026 10:12 pm
 Post subject: Best Cap And Rotor
PostPosted: Wed Jan 11, 2012 6:44 pm
what/where are the good stuff?
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Wed Jan 11, 2012 7:07 pm
Standard CH410(with brass contacts) and the echelin MO-3000 extended tip rotor.
PostPosted: Wed Jan 11, 2012 7:16 pm
^ What he said,but i have the CH-410X cap.
DRIVE IT,DON'T HIDE IT
PostPosted: Wed Jan 11, 2012 7:20 pm
where do i have to go to get the rotor? both caps came up on summit...
P.S. whats the difference between the caps?
PostPosted: Wed Jan 11, 2012 7:23 pm
NAPA has the rotor. Ch410x Was the blue cap with brass contacts,and was discontinued,it is now CH410.Make sure you get the right cap when you order it. Should be blue with brass contacts.
PostPosted: Wed Jan 11, 2012 7:25 pm
http://www.summitracing.com/parts/SMP-CH410/
even have the X, special order though
http://www.summitracing.com/parts/SMP-CH410X/
and a call to napa is in order!
thanks!
PostPosted: Wed Jan 11, 2012 7:28 pm
I am in the process of talking to summit about the caps,to make sure I get the right one. I sent them an email,and if I dont hear back by tomorrow I will be calling them. I will let you know what I hear.
Be careful with the rotor,check it before you buy it. It should be tan not black,and the tip should be noticeably longer.Take an old rotor with you when you pick it up.
PostPosted: Wed Jan 11, 2012 7:29 pm
email them?? lol just call them... i'll do it right now... Be back in a sec
PostPosted: Wed Jan 11, 2012 7:33 pm
said it was blue with brass contacts... the ch410
they dont carry the rotor...
PostPosted: Wed Jan 11, 2012 7:36 pm
Cool,I will order mine now then.
vatozone has this thing to...
accel cap with copper?? contacts, stock rotor though...
http://www.autozone.com/autozone/parts/ ... 45590_1481
PostPosted: Wed Jan 11, 2012 7:52 pm
Duracrap the accel cap is garbage too the two that I tried wore out the center contact in under 200 miles. For cheap caps I have always used the MO40 from napa,but after much research I am trying out the CH410,its supposed to be the bees knees for slants/3.9's.
PostPosted: Wed Jan 11, 2012 7:58 pm
http://www.napaonline.com/Catalog/Catal ... cType%3aA)
here is the rotor...
PostPosted: Wed Jan 11, 2012 8:02 pm
another cap from napa... same make as the rotor
any good? have brass contacts
EDIT:
nevermind it has 8 towers lol...
PostPosted: Wed Jan 11, 2012 8:13 pm
ok thanks guys! ordered my ca thru summit and rotor thru napa online!
Users browsing this forum: Google [Bot] and 10 guests
