| clutch fork pivot question https://slantsix.org/forum/viewtopic.php?t=47635 |
| Author: | nuttyprof [ Thu Jan 19, 2012 10:52 pm ] |
| Post subject: | clutch fork pivot question |
I need the dimensions for the clutch fork pivot in an a833od bellhousing. It looks like it should be similar to the one in my '62 3 speed bell, but I don't know if it is interchangeable. the fork has a groove across it and a metal tab riveted in to hold it to the support. I do not know what year it came from or I'd tell you that. I think if I can find out the height of the support and the size and position of the hole I could make one. Thanks for any info you share nuttyprof |
