It is currently Sun May 10, 2026 12:37 am
 Post subject: Good block and crank?
PostPosted: Sat Jan 21, 2012 8:09 pm
Car Model: Lancers
I am building a turbo'd engine. I have some blocks with the cast crank. Are the blocks good? Are the forged cranks from the early engines compatable with the late blocks? :?:
PostPosted: Sat Jan 21, 2012 8:32 pm
http://www.slantsix.org/articles/dutra- ... blocks.htm
PostPosted: Sun Jan 22, 2012 6:31 am
I would not worry about using a cast crank motor unless you are shooting for over 450-500 HP. Several 400+HP motors have been cast crank.
No, you cannot "drop in" a forged crank into a cast block, but some creative machining could make it happen.
PostPosted: Sun Jan 22, 2012 6:31 pm
Car Model: Lancers
I had read the article by Doug but was hoping that a forged crank from a early motor would fit into a cast crank block. Thanks for the info.
PostPosted: Sun Jan 22, 2012 6:44 pm
Best and easiest to find a complete forged crank block and crank...
PostPosted: Sun Jan 22, 2012 7:12 pm
Car Model: Lancers
Oh well I guess I need another motor. Evidently more than a dozen isn't enough. All just the wrong ones.
