| Good block and crank? https://slantsix.org/forum/viewtopic.php?t=47662 |
| Author: | moparfrank [ Sat Jan 21, 2012 8:09 pm ] |
| Post subject: | Good block and crank? |
I am building a turbo'd engine. I have some blocks with the cast crank. Are the blocks good? Are the forged cranks from the early engines compatable with the late blocks? |
| Author: | Joshie225 [ Sat Jan 21, 2012 8:32 pm ] |
http://www.slantsix.org/articles/dutra- ... blocks.htm |
| Author: | Dart270 [ Sun Jan 22, 2012 6:31 am ] |
I would not worry about using a cast crank motor unless you are shooting for over 450-500 HP. Several 400+HP motors have been cast crank. No, you cannot "drop in" a forged crank into a cast block, but some creative machining could make it happen. Lou |
| Author: | moparfrank [ Sun Jan 22, 2012 6:31 pm ] |
I had read the article by Doug but was hoping that a forged crank from a early motor would fit into a cast crank block. Thanks for the info. |
| Author: | Dart270 [ Sun Jan 22, 2012 6:44 pm ] |
Best and easiest to find a complete forged crank block and crank... Lou |
| Author: | moparfrank [ Sun Jan 22, 2012 7:12 pm ] |
Oh well I guess I need another motor. Evidently more than a dozen isn't enough. All just the wrong ones. |
