| made in USA universals https://slantsix.org/forum/viewtopic.php?t=47702 |
| Author: | DadTruck [ Tue Jan 24, 2012 1:10 pm ] |
| Post subject: | made in USA universals |
ordered a set of Precision Super Strength drive shaft universals through RockAuto,, pleasantly surprised when the Precision box that they came in was also marked Federal Mogul and made in the USA |
| Author: | Greg Ondayko [ Tue Jan 24, 2012 1:17 pm ] |
Sometimes with the precision 246 U joints I find that they are a snug fit on the bearing cap retainer rings (which is a good thing..) sometimes you need to file a bit on the inner part of the driveshaft ears (not on the circular part that you press the bearing caps through, but on the 2 1/8 dimension ) to get the bearing cup retaining rings to fit /seat correctly. Good Stuff.. Greg |
| Author: | DadTruck [ Tue Jan 24, 2012 1:40 pm ] |
Greg the Precision 246's I bought are for the 83 D-150,, are you saying the 246 also fits A body drive shafts? |
| Author: | slantzilla [ Tue Jan 24, 2012 2:20 pm ] |
Probably a 7260 joint John. For the most part Mopar has only used 3. 7260, 7290, and 1350. Somewhere online there is a page with all the cross-over numbers. I used to have it bookmarked, but lost it. Greg, Precision is about the only joint I ever had to do that with. Their dimensions seem just a tick off. |
| Author: | Greg Ondayko [ Tue Jan 24, 2012 2:35 pm ] |
They Fit ALOT OF JUNK! http://www.summitracing.com/parts/PCN-2 ... refilter=1 Anything with 2 1/8" u joints aka Small mopar u joints. Losta stuff had them G |
| Author: | DadTruck [ Tue Jan 24, 2012 2:55 pm ] |
SZ and GO,,, thanks, that is all good-to-know-info |
