It is currently Tue Jun 23, 2026 8:06 am
 Post subject: Pans
PostPosted: Thu Jan 26, 2012 7:37 am
I know that early and the later 67 up oil pans are different,but are the oil pickups? What makes the later pan non usable in the 66-early cars ?
PostPosted: Thu Jan 26, 2012 8:28 am
Question along the same line: to put a 1974 engine in a 1964 car(DART), do you need to change anything other than the oil pan and pickup?(do you need to chage the pickup?)
1964 Dart GT
PostPosted: Thu Jan 26, 2012 8:35 am
The sump on a 67 and up SL6 A-Body oil pan is more forward and hits on the K-frame.
See this thread for more details:
http://www.slantsix.org/forum/viewtopic ... n+pictures
As for swapping a 68 and newer SL6 into a early vehicle, you may need a different flywheel (manual shift) or a "spacer" for the back of the crank to adapt to the smaller torque converter pilot hub.
PostPosted: Thu Jan 26, 2012 8:41 am
keeping the original 904 automatic(1964) and putting in 1974 225 SL6, differant size Torque Converter? Oops...re-read "pilot hub"!
1964 Dart GT
PostPosted: Thu Jan 26, 2012 8:48 am
Sounds like you will need an adapter ring.
I have some in stock... send me a PM if you need one
