| aluminum drive shaft? https://slantsix.org/forum/viewtopic.php?t=47754 |
| Author: | USAJon [ Sun Jan 29, 2012 2:08 pm ] |
| Post subject: | aluminum drive shaft? |
anyone ever run one..? like? |
| Author: | Reed [ Sun Jan 29, 2012 2:18 pm ] |
My 89 Ford van was built with one from the factory. It was very light and did a good job transferring the rotational force form the transmission to the rear axle. I swapped it out for a steel driveshaft due to transmission and rear axle changes, but i will be reinstalling the aluminum driveshaft eventually. The only real advantage to an aluminum driveshaft is weight savings. |
| Author: | USAJon [ Sun Jan 29, 2012 2:36 pm ] |
any idea about average weight savings.. |
| Author: | Greg Ondayko [ Sun Jan 29, 2012 6:45 pm ] |
And More power gets to the rear tires with that weight savings. Greg |
| Author: | Greg Ondayko [ Sun Jan 29, 2012 6:49 pm ] |
i will be getting An Aluminum or Carbon Fibre Driveshaft when Budget allows. Better et's Greg |
| Author: | Shaker223 [ Sun Jan 29, 2012 7:07 pm ] |
I have an aluminum drive shaft. http://www.dynotecheng.com/ |
| Author: | SlantSixDan [ Sun Jan 29, 2012 7:35 pm ] |
Quote: And More power gets to the rear tires with that weight savings.
Er-ruh……uh… :shrug: |
| Author: | Danarchy [ Sun Jan 29, 2012 7:49 pm ] |
Never had an aluminum driveshaft, but Denny's makes quality products. I had a HD & a stub shaft for my Jeep made by them years ago. http://www.dennysdriveshaft.com/index.html |
| Author: | Dart270 [ Sun Jan 29, 2012 7:55 pm ] |
Have one in my '64 Dart, for last 9-10 yrs, from Denny's. 7-8lbs wt savings, IIRC. Lou |
| Author: | sixinthehead [ Mon Jan 30, 2012 2:09 pm ] |
My Dart has one, came from the JY. Marked "Ford van", a la Reed. Tape measure said it was the right length, used a hybrid u-joint to match it to the yokes, and away we go. I didn't weigh it, though. But I can feel all that extra power!!!! |
