| Slant 6 on an Engine Stand https://slantsix.org/forum/viewtopic.php?t=47755 |
Page 1 of 2 |
| Author: | Danarchy [ Sun Jan 29, 2012 3:01 pm ] |
| Post subject: | Slant 6 on an Engine Stand |
I have had numerous engines(motors) on my stand, but the Slant 6 is by far the weirdest! (3 Bolts through, 1 Bolt In) Any tricks to mounting it better? Just not 100% comfortable with how it mounts. |
| Author: | Aggressive Ted [ Sun Jan 29, 2012 3:16 pm ] |
I use four my self. I just like all the weight to spread across (4) grade 8's. |
| Author: | Reed [ Sun Jan 29, 2012 3:45 pm ] |
Here is the best way I have found to mount a slant six (and this one is fairly sturdy, even though it is mounted to a three wheel stand and has a head bolted on):
| Author: | Danarchy [ Sun Jan 29, 2012 4:06 pm ] |
I have a wide 4 wheeled stand, and yes Grade-8 bolts, and I have it mounted very similar to your picture Reed, but I have the top left mount bolted through the top starter hole. I rolled it all around the garage and it’s not going to tip over or anything, it just doesn’t feel solid?(balanced like a V8 ) I do have the head on too. Must just be me.-Thanks Dan |
| Author: | DusterIdiot [ Sun Jan 29, 2012 4:06 pm ] |
| Post subject: | X2 |
Reed mounts it like I mount mine....2 top bolts to the block the two bottom ones are through bolts. -D.Idiot |
| Author: | Fab64 [ Sun Jan 29, 2012 5:33 pm ] |
Here's how I did it:
| Author: | Red [ Sun Jan 29, 2012 5:43 pm ] |
+100 on a 4-wheeler with two base spars/arms: ![]() being far stabler than a stand with only base 1 spar/arm: ![]() Worth the extra expense without a doubt, IMHO, when it comes to avoiding the BIG "ooops!". |
| Author: | Danarchy [ Sun Jan 29, 2012 7:31 pm ] |
Quote: Here's how I did it:
That is how mine is mounted. The Slant scares me! ![]() |
| Author: | Joshie225 [ Sun Jan 29, 2012 8:54 pm ] |
I always try to get the engine plate as high up as possible (close to the block deck/cylinder head) so that the center of gravity is lower and also more centered when the engine is tilted. |
| Author: | stop the beast [ Sun May 13, 2012 12:22 pm ] |
I know this thread is getting a bit old. But what size bolts are you guys using? Look like I'll need three bolts with nuts and washers and one to bolt into the block. Length, size and pitch would be awesome. |
| Author: | Ccrussell [ Wed Sep 05, 2018 10:31 am ] |
| Post subject: | Re: Slant 6 on an Engine Stand |
Hello, Ok just picked up a super six . Complete motor which i would like to put on an engine stand. Anyone ever figure out which correct bolts are required? Still searching... |
| Author: | slantzilla [ Wed Sep 05, 2018 9:33 pm ] |
The two that screw into the top bellhousing holes are 3/8" coarse thread. Length depends on the length of the tubes on your stand. I go through the bottom open holes. They take 7/16" bolts and nuts. Again, length depends on your stand. I think I have also gotten 1/2" bolts through the open holes. |
| Author: | Badvert65 [ Thu Sep 06, 2018 7:31 am ] |
I mount my slants to the stand in a slightly odd way, but it gets the center of gravity lower. Attachment: Attachment:
If you look closely, I flopped the top arms around and bolted the top two engine bolts directly to the engine stand head. I am just using the arm as a spacer. The lower two arms mount in the usual way. I haven't run into any problems with the engine mounted this way. It just lowers the entire assembly so it doesn't feel quite so top heavy. |
| Author: | and739 [ Thu Sep 06, 2018 8:26 am ] |
Good tip, Matt. You're thinkin' outside the box right there. Thanks for sharing |
| Author: | Greg Ondayko [ Thu Sep 06, 2018 4:25 pm ] |
Who knew there were so many correct ways to mount one of these to a stand? Greg |
| Page 1 of 2 | All times are UTC-07:00 |
