It is currently Mon Jun 15, 2026 6:33 am
PostPosted: Mon Jan 30, 2012 10:27 am
There is a ~3/8" ~fine thread hole in the top of the head on the carb side of the valve cover , in the valve cover flange surface, middle of the head (front to back). Is this a mounting hole for a head temp sensor?? what thread pitch?
We got our slant 6 fired up and running and found several water leaks. This small hole was not leaking, but it was bubbling and steaming a bit. it looked like more steam that one would have if we were just boiling off a little water in the hole, meaning it seem to bubble and steam like it was a small crack into the water jacket??
I'm assuming we could just run a bolt in to seal it off, or install a temp sensor or ???
Dan H
Dudes Ex Machina
PostPosted: Mon Jan 30, 2012 10:46 am
Are you looking at the 2 raised bosses, just outside of the valve cover?
(one near the center and other one toward the rear of the engine)
These threaded holes / mounting points are used to lift the engine / trans assembly, for installation into the vehicle.
They are 3/8-16 unc threads
 Post subject: Holes
PostPosted: Mon Jan 30, 2012 11:20 am
Yeah, I think that center one is the one I was referring too. OK, its just the lifting hole. So we can bolt that closed and put a little sealant on it for now.
Thanks very much for the picture and the help.
Dan H
Dudes Ex Machina
 Post subject: third hole
PostPosted: Mon Jan 30, 2012 11:53 am
There is a third hole on some heads. Back two are mounting points like doc mentioned third is for temp sensor.
[/img]
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
 Post subject: Lol...
PostPosted: Mon Jan 30, 2012 6:41 pm
There can be a couple others in that location if you have a 1981+ head...
PostPosted: Mon Jan 30, 2012 7:43 pm
The two middle holes shouldn't need anything put in them. They don't go into the water jacket. If you have coolant coming out of the middle holes then you have a problem.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
