It is currently Mon Oct 12, 2026 5:47 pm
PostPosted: Tue Jan 31, 2012 5:43 pm
Ok, ill be short and sweet- heres what i need.
crank journal measurements and con-rod journal measurements-stock
bore diameter-stock
i gotta measure everything out to see how worn out it is before i take it to the machine shop. Hoping everything is within reasonable specs. I searched a little for these but couldnt find anything without searching through hundreds of pages of info. Thanks in advance guys!
87 Dodge B150 Slant 6 Auto
PostPosted: Tue Jan 31, 2012 5:58 pm
Mains @ 2.750
Rods at 2.187
Cylinder Bore @ 3.400
PostPosted: Tue Jan 31, 2012 9:31 pm
Thank you doc, that works perfect.
PostPosted: Wed Feb 01, 2012 1:57 pm
hevent measured the mains or the cylinders yet, but the rod journals measure 2.114. so they are worn close to .070..... time for a new crank i think. S&*t.
Users browsing this forum: DuckDuckGo [Bot] and 30 guests
