| torque converter question https://slantsix.org/forum/viewtopic.php?t=47805 |
| Author: | kielbasa [ Thu Feb 02, 2012 7:13 pm ] |
| Post subject: | torque converter question |
say if one were to have a later car, with a big hole converter. and one picked up an engine with a small hole crank, would one be able to switch out the converter to a small hole, with out any problems? also is there a picture anywhere for side by side comparison? |
| Author: | Fopar [ Thu Feb 02, 2012 7:16 pm ] |
No the input shaft is smaller in diameter Richard |
| Author: | kielbasa [ Thu Feb 02, 2012 7:30 pm ] |
wtf was dodge thinkin, ohwell thanks! |
| Author: | Fopar [ Thu Feb 02, 2012 7:42 pm ] |
My 63 Dart has the small hole early crank and the transmission has a smaller diameter input shaft. The later large hole crank transmissions had larger input shafts. Richard |
| Author: | Charrlie_S [ Thu Feb 02, 2012 8:13 pm ] |
You can have a converter built to fit the small hole crank and the large input shaft trans. I have all of my converters were made that way. |
| Author: | kielbasa [ Thu Feb 02, 2012 8:21 pm ] |
well a fellow member needs a crankshaft, and he is having hard time finding one local for the right price i guess, but all i have is a small hole crank, but also have the matching converter. but i guess it doesn't matter lol (he has late car) |
| Author: | Vanopolis [ Mon Feb 20, 2012 11:48 am ] |
I'm having a similar problem and I'm looking into having my crankshaft machined out larger to match up with my torque converter. |
| Author: | Dart270 [ Mon Feb 20, 2012 12:12 pm ] |
If your crank is out, this is a good idea. Doc has done this with success. I've never tried it, but it should work. Lou |
