| Oil pump leaks on garage floor replacing the gasket or pump? https://slantsix.org/forum/viewtopic.php?t=47808 |
| Author: | hideogumperjr [ Thu Feb 02, 2012 11:12 pm ] |
| Post subject: | Oil pump leaks on garage floor replacing the gasket or pump? |
Hi Guys. I have a 63 dart with 125k on the engine and it is leaking some oil when sitting in my garage. Should I just replace the seal when I pull the oil pump or should I replace the pump with a new one since its out? Thanks John |
| Author: | hantayo13 [ Fri Feb 03, 2012 6:53 am ] |
did you try retorqueing the bolts???? |
| Author: | 69a100 [ Fri Feb 03, 2012 7:36 am ] |
Which gasket is it leaking from, the block or the pump? |
| Author: | hideogumperjr [ Fri Feb 03, 2012 8:52 am ] |
| Post subject: | /6 leaking oil in garage should I replace just the seal or t |
I have not tried to retighten the bolts yet still in exploratory mode and I am not sure if it is the pump or the seal. I figured once I lifted things up and got access to the pump I could check it all out, I already have the pump to engine gasket and thought I would replace it since it I access. Sounds like I should do some more digging first? Thanks for the quick responses. We have a beautiful sunny warm day here is Seattle its almost 50°! |
| Author: | Fopar [ Fri Feb 03, 2012 10:25 am ] |
First clean the area and the pump (external) then drive or run engine to see where the oil is really coming from. Might just be a leaky sender unit. Richard |
