| Offy vs. Weiand 4bbl https://slantsix.org/forum/viewtopic.php?t=47846 |
Page 1 of 2 |
| Author: | raPoM [ Tue Feb 07, 2012 7:15 pm ] |
| Post subject: | Offy vs. Weiand 4bbl |
I have an offy and weiand 4bbl intake. I need to sell some parts to get my truck going. I am trying to decide which manifold might be better to use,and I am going to sell the other. My observations: The offy has a larger plenum area. The weiand is slightly taller and the runners are slightly bigger. Everything seems about the same. I had planned on running the weiand,and selling the offy...but I like the looks of the offy's plenum....I am curious to see if you guys think there might be an advantage to one or the other before I sell one of them. For my 87 D100 Eddy 500,hooker LT headers,HEI,and 4.56's stock engine otherwise. I do realize that if there is a diff. it will be very small,and will prob. not be noticeable in my application.
| Author: | raPoM [ Tue Feb 07, 2012 7:28 pm ] |
| Author: | raPoM [ Tue Feb 07, 2012 8:56 pm ] |
Decided to stick with the Weiand |
| Author: | Rug_Trucker [ Wed Feb 08, 2012 10:10 am ] |
If I had both I would use the Weiand just because there is less of them out there. |
| Author: | raPoM [ Wed Feb 08, 2012 10:17 am ] |
Quote: If I had both I would use the Weiand just because there is less of them out there.
That is exactly what swayed my decision. Even if im loosing out on a small% of hp/tq,its worth it for the coolness factor to me.
| Author: | Danarchy [ Wed Feb 08, 2012 12:26 pm ] |
Quote: coolness factor Ditch both of them and buy a short runner AussieSpeed! |
| Author: | raPoM [ Wed Feb 08, 2012 1:14 pm ] |
Quote: Quote: coolness factor Ditch both of them and buy a short runner AussieSpeed! |
| Author: | Danarchy [ Wed Feb 08, 2012 2:22 pm ] |
Quote: the old Weiand is wayyyy cooler o.k. |
| Author: | Aggressive Ted [ Wed Feb 08, 2012 3:16 pm ] |
| Post subject: | Weiand Manifold |
raPoM, I also picked up an old Weiand intake manifold for the SL6. I had it bead blasted and ceramic coated with a clear sealer. It will go on my updated "Torque and Mileage" block. I am hoping that the Weiand runners will provide better mixing and produce better low end torque over a Clifford or Offy. We will have to compare notes later this summer. Your truck build verses my car build. |
| Author: | slantzilla [ Wed Feb 08, 2012 3:29 pm ] |
I have only seen one Weiand live and in person, and it was on a race car. Seemed to work fine as far as I could tell. Not seeing much real world love for the Hurricane stuff. |
| Author: | raPoM [ Wed Feb 08, 2012 3:41 pm ] |
| Post subject: | Re: Weiand Manifold |
Quote: raPoM,
Ted-I also picked up an old Weiand intake manifold for the SL6. I had it bead blasted and ceramic coated with a clear sealer. It will go on my updated "Torque and Mileage" block. I am hoping that the Weiand runners will provide better mixing and produce better low end torque over a Clifford or Offy. We will have to compare notes later this summer. You know it buddy! |
| Author: | raPoM [ Wed Feb 08, 2012 3:44 pm ] |
Quote: I have only seen on Weiand live and in person, and it was on a race car. Seemed to work fine as far as I could tell.
My(hurricane) manifold had some pretty major core shift going on,and after replacing my clifford with it and spending a few weeks tuning it, I had had enough and sold it to a member here. It just did not seem to live up to the claims that AS makes.The clifford had it beat on low-mid-and top end.... I was very disappointed,especailly after shelling out 500 bux for it Not seeing much real world love for the Hurricane stuff. |
| Author: | raPoM [ Wed Feb 08, 2012 3:45 pm ] |
Some Weiand/Eddy eye candy:
| Author: | terrylittlejohn [ Wed Feb 08, 2012 3:54 pm ] |
only used an offy on the street and racing with everything from a 390cfm up to a 750dp cfm, runners are closer in length and bigger plenum + 2" spacer. have no complaints;no comparision either. |
| Author: | Rug_Trucker [ Fri Feb 10, 2012 10:33 am ] |
It looks like the Hurricane has more equal length runners. Do the Clifford and Offy have distribution issues like a stock intake? I would really like to see dyno results. I sold my Offy because a 2bbl is all I need for now. I want to go turbo on the Duster hopefully EFI. |
| Page 1 of 2 | All times are UTC-07:00 |
