slant six harmonic balancer
https://slantsix.org/forum/viewtopic.php?t=47859
Page 1 of 1
Author:  mopar rat rod [ Thu Feb 09, 2012 5:44 pm ]
Post subject:  slant six harmonic balancer
i have a 71 slant with a bad balancer, outer ring came off the hub on the crank. no experience with slants. no bolt in center of crank ( should there be ?) holding it on. 1st, how do you get it off? 2nd where can i get a good one? any help would be very much appreciated
Author:  805moparkid [ Thu Feb 09, 2012 5:54 pm ]
falcon global on ebay sells both the Romac SFI unit and also another aussie made unit that is a very nice peice...
there on ebay under slant six, or slant 6
Author:  slantzilla [ Thu Feb 09, 2012 5:54 pm ]
Use a steering wheel/balancer puller. You can get one at any parts store, some even loan them.
No bolt is normal.
Google Damper Doctor/Damper Dudes for rebuilt dampers.
:D
Author:  mopar rat rod [ Thu Feb 09, 2012 6:46 pm ]
thanks guys, checked out the balancers , the aussie one sats it fits 60 tru 84. in 76 the slant got a cast crank will this one work on my 71?? how can it work on both??
Author:  ceej [ Thu Feb 09, 2012 6:51 pm ]
Yep. It'll work.
Author:  mopar rat rod [ Thu Feb 09, 2012 6:54 pm ]
thank you
Author:  ceej [ Thu Feb 09, 2012 7:04 pm ]
If it's for a hot rod, the Aussie one looks pretty sharp.
I have a nice SFI Damper. It weighs a ton compared to the OEM ones. Might actually have enough mass to dampen harmonics on the crank, but I doubt it. :lol:
A '71 crank is forged.
Author:  slantzilla [ Thu Feb 09, 2012 7:05 pm ]
Make sure it has multiple timing marks. The location of the mark/tab changed in the late '60's.
