| Holley 1920 throttle lever spring - connect to what? https://slantsix.org/forum/viewtopic.php?t=47923 |
Page 1 of 2 |
| Author: | 1966DartConvertible [ Thu Feb 16, 2012 12:47 am ] |
| Post subject: | Holley 1920 throttle lever spring - connect to what? |
Hi again Im just wondering, on a standard factory slant six equipped with Holley 1920, what keeps the throttle lever (and butterfly) in the closed position? I would imagine some kind of spring? If so, where should this spring be connected to? Here is my current setup (see the spring on the right) ![]() I do not have the well type choke thermostat there at the moment but soon i will, so where should I connect the spring to then (i mean as per factory)? Thanks. Syed |
| Author: | Aggressive Ted [ Thu Feb 16, 2012 8:18 am ] |
Syed, Click on the red link below my name to view pictures of the spring attach points. |
| Author: | SlantSixDan [ Thu Feb 16, 2012 10:56 am ] |
You're missing the throttle spring bracket. |
| Author: | Reed [ Thu Feb 16, 2012 12:13 pm ] |
What Dan said: ![]() I happen to have an extra one barrel throttle return spring bracket gathering dust in my garage. Are you interested in it?
| Author: | ESP47 [ Thu Feb 16, 2012 1:05 pm ] |
Put me 2nd in line if Syed doesn't want it |
| Author: | Reed [ Thu Feb 16, 2012 1:19 pm ] |
I think I might have two, as well as some old Holley and Carter one barrel thermostatically assisted choke pulloff coil assemblies. I need to go dig around in my parts stash. |
| Author: | Nongan [ Thu Feb 16, 2012 1:37 pm ] |
I believe I have one also, in case reed cant find his second one Seth |
| Author: | SlantSixDan [ Thu Feb 16, 2012 3:13 pm ] |
Note the pictured throttle spring bracket is a later variety, not the more vertical type that would have come on Syed's '66. The later horizontal spring bracket requires a spring with an extended hook/leg as shown in Reed's photo, not the type shown in Syed's photo. |
| Author: | Reed [ Thu Feb 16, 2012 3:17 pm ] |
Ah! Thanks for pointing that out Dan. I'll see if I have the other style bracket. |
| Author: | SlantSixDan [ Thu Feb 16, 2012 3:50 pm ] |
…or a spare long-legged throttle spring... |
| Author: | Reed [ Thu Feb 16, 2012 4:04 pm ] |
I probably DO have an extra long-legged spring. I found these while I was rooting around in one of my parts bins in my attic: ![]() The throttle spring bracket on the far left is the one i posted a picture of before. The second throttle return spring bracket looks like it is another late version that has had the leg cut off and the spring loop arm bent a bit. The thermostatically assisted choke pulloff assembly looks like it is for an early carb with the closed well, but I don't know if it is a Holley or a Carter. Unfortunately, it looks as if the rod for the choke linkage has ben bent out o its original shape. I might have more parts squirreled away, but I need time to dig them out. The simplest solution is for you to bend up a piece of metal, bolt it to the motor, and run a spring from the carb to the piece of metal. |
| Author: | 1966DartConvertible [ Thu Feb 16, 2012 4:25 pm ] |
Quote: Note the pictured throttle spring bracket is a later variety, not the more vertical type that would have come on Syed's '66. The later horizontal spring bracket requires a spring with an extended hook/leg as shown in Reed's photo, not the type shown in Syed's photo.
Is this the vertical one you are talking about Dan? (pic taken from FABO)If so, anyone has this? or maybe a well-type choke thermostat for pre-'73 as well? anyone? Anyway, I managed to make a quick make-shift bracket for temporary use, until I can get the correct one. Obviously this would not work with the choke thermostat in place... ![]() Syed |
| Author: | SlantSixDan [ Thu Feb 16, 2012 8:11 pm ] |
Yes.
| Author: | 1966DartConvertible [ Thu Feb 16, 2012 8:45 pm ] |
Yes.Thanks Syed |
| Author: | 1966DartConvertible [ Wed Feb 22, 2012 7:42 pm ] |
Quote: I think I might have two, as well as some old Holley and Carter one barrel thermostatically assisted choke pulloff coil assemblies. I need to go dig around in my parts stash.
Hi Reed, did you find anything?Syed |
| Page 1 of 2 | All times are UTC-08:00 |
