| Leanburn question https://slantsix.org/forum/viewtopic.php?t=47931 |
| Author: | raPoM [ Fri Feb 17, 2012 10:53 am ] |
| Post subject: | Leanburn question |
Problem after problem. I decided to install my 4bbl,and HEI this weekend. After pulling the manifolds(and finding 3 broken studs),and getting the 4bbl together I find out my dist. is bad,im not getting any signal from it,and no spark. I am now ordering a new one from OCPNW. My question is: Will I be able to drive around without doing the HEI swap,while I wait for my new dist to come in? I am wondering if the truck will still drive ok with the 4bbl,and the LB computer still controlling the timing? I only have a 4 mile commute each way to school,and all on back roads no major highways.This is not permanent, I just need to be able to drive my truck to school until I get the new dist. Thanks |
| Author: | SlantSixDan [ Fri Feb 17, 2012 10:58 am ] |
I can't see why not…but there's one sure way to find out! |
| Author: | raPoM [ Fri Feb 17, 2012 11:02 am ] |
Hahaha,thanks Dan. I just need to replace the stud in the exa. manifold,button it all up and pray that it fires |
| Author: | Reed [ Fri Feb 17, 2012 12:19 pm ] |
Just be sure your base timing is set at 16 BTDC and the vacuum hose to the computer gets a manifold/non-ported vacuum feed. |
| Author: | raPoM [ Fri Feb 17, 2012 1:12 pm ] |
Ok,Thanks Reed. |
