| passenger side steel brake line https://slantsix.org/forum/viewtopic.php?t=47933 |
| Author: | Ed Mullen [ Fri Feb 17, 2012 5:40 pm ] |
| Post subject: | passenger side steel brake line |
I got a full set of steel brake lines for the Valiant from inline tube. I was going to only install the ones that really need replacing, and leave the rest for some future large-scale disassembly project. I was on a roll last weekend, and just disconnected all of them and began removing them when I realized that the one along the firewall goes under the engine harness, heater hoses, throttle cable, blower motor and wiper motor. Is there a trick to getting this one in and out, or do I have to remove/disconnect all that stuff? (like if I jack the front end high enough I can rotate the old tube counterclockwise and remove under the car, then rotate the new one the opposite way, only disconnecting a few things.) |
