| Ongoing problem with reman. Holley 1920 carbs https://slantsix.org/forum/viewtopic.php?t=47947 |
| Author: | apairof66s [ Sun Feb 19, 2012 7:12 am ] |
| Post subject: | Ongoing problem with reman. Holley 1920 carbs |
Since joining this Forum I've been through 3 Holley model 1920 carbs. This last one apparently has parts inside that are missing !! I pulled it and gave it to a old school mopar mechanic and had him take it apart to see what the problem is this time. The 1 bbl is (was) on my sons 64 Dart w/ a 225. It wouldn't start unless I primed the carb w/ approx. 1 oz. of gas straight into the throat. After that it would run fine. In the meantime we've ordered another reman. and have to wait to see if one is available. Can I go with a Carter 1 bbl. on the same intake ? The throttle linkage is orginal and correct for the year, (pre-cable set up). It does have the choke coil on the intake as well........ Any advice would be greatly appreciated. |
| Author: | SlantSixDan [ Sun Feb 19, 2012 10:03 am ] |
Yes, you can put on a Carter, but as long as you keep putting on "remanufactured" carburetors, you're going to keep having problems. They're trash. See thread on the topic linked from the post here. I am pretty sure I'm out of new carburetors to fit your '64 right now, but send me a PM and I'll see what I can find. |
