| How many forward gears can we fit into this thing? https://slantsix.org/forum/viewtopic.php?t=48 |
| Author: | Dart270 [ Mon Oct 21, 2002 11:22 am ] |
| Post subject: | How many forward gears can we fit into this thing? |
Maybe this site will finally get me to set up a pic site of my own? Only the Shadow knows. Hmm, mm, mm, mm, mmmm... Lou |
| Author: | Doc [ Mon Oct 21, 2002 11:47 am ] |
| Post subject: | Who will have the first 6 Speed SL6?? |
Does any OEM make a seven speed manual gear box? As for Moderator for this section, you are hired! I will get with Chuck o changing your access and rank. DD |
| Author: | Dart270 [ Mon Oct 21, 2002 11:54 am ] |
| Post subject: | cool beans |
Sounds cool, my good Doctor - I'm in. I guess an "infinte speed" (CVT) might be up next? I may have heard of a 7-speed, hafta check with my Chrysler design buddy who keeps up on that stuff worldwide. The T56 would probably not be a big swap into my Dart at this point. That's a big ticket though: ~$1200 used and ~ $3000 new. Found out that VIR is only 70 minutes from here, and Roxboro dragstrip is only 50-60 min. Time for some recon... Lou |
| Author: | Patrick Devlin [ Wed Oct 23, 2002 9:53 pm ] |
| Post subject: | First post on new board! I like it already |
This is cool By the way, I got my A833 OD bellhousing and 4spd. floor hump this week. I'm that much closer to installing a MT in my car |
| Author: | Dart270 [ Thu Oct 24, 2002 6:36 am ] |
| Post subject: | cool. |
Good to see you on the board, Patrick. Gotta love the stick, Lou |
| Author: | Matt Haskell [ Thu Oct 24, 2002 8:35 am ] |
| Post subject: | Nice.. |
Good to see everything up and running. Looking forward to see how it all turns out. Far better investment than a service manual, and more entertainment than most movies.. Considering the title of this thread is about forward speeds, check out 5speeds.com, they have a dog ring t-5 setup... 'Look mom, no clutch..', just what we need to get when the lottery hits.. matt- |
| Author: | Dart270 [ Thu Oct 24, 2002 9:45 am ] |
| Post subject: | Good to see ya - cool site... |
Good info on that 5speed site. Nice close ratios on that JT5 too. I'd like to swap my 5th over to 0.68 or 0.78 from the 0.63 at some point. Still, If I stick with my 3.91 gears I can handle many road courses without going to 5th anyway (110 MPH at 5800 RPM in 4th). Cheers, Lou |
| Author: | andrew [ Thu Oct 24, 2002 1:53 pm ] |
I just got my pedal assembly, so I will also be looking for a 5 speed to put in. Lou will the trans you have hold up to 350 hp? Andrew Wagner |
| Author: | mustangsix [ Wed Oct 30, 2002 1:51 pm ] |
There is actually a "seven speed" OEM transmission. The C4 Corvette had a 4+3 Muncie for two years. It was basically a 4 speed with an overdirve that also operated on the 2nd-4th gear. Used as a gear splitter you could get seven forward gears. |
| Author: | Dart270 [ Wed Oct 30, 2002 9:10 pm ] |
| Post subject: | T5 open to debate... |
Mustangsix- yep, forgot about that one. Not quite a legitimate 7 speed, but it counts. That Gear Vendors OD might work for an application like that too. Andrew - the torque rating on my T5 is 330 ft.-lbs. I have heard of guys saying that it'll handle 350 HP, but that is nearing the upper end. I'd say it's open to debate, but if you're running mid-14s, then you should be OK with it. If you plan on boosting HP on your engine further, then I would recommend going to the Tremec 3550 trans, or even the TKO. These are only marginally more expensive than the T5 (and heavier, TKO by 30 lbs), but can handle a lot more power. The TKO can take anything a Slant can dish out (like 700 ft-lb max), and the 3550 can take around 450 ft-lbs. Keisler has the kits, but they should be about the same to adapt as the T5. I figure I saved about $1000-1400 by doing the engineering and machining myself vs. buying their kit, but it was at least 40 hrs. additional work. Course, anyone following my instructions should take less time... For swapping from an auto, I highly recommend the hydraulic clutch linkage too, if you can float the dough. I will be doing a writeup on the T5 swap pretty soon, and I am happy to answer any questions before then. Cheers, Lou |
| Author: | Chuck [ Wed Oct 30, 2002 9:28 pm ] |
| Post subject: | Re: T5 open to debate... |
Quote: I will be doing a writeup on the T5 swap pretty soon
Looking forward to that! |
