| Tranny diagnosis https://slantsix.org/forum/viewtopic.php?t=48006 |
| Author: | Chuck [ Sat Feb 25, 2012 7:47 pm ] |
| Post subject: | Tranny diagnosis |
I have a rebuilt tranny ready to go in my Dart but I want ti pre-diagnose the old one so I can make sure I correct the problem. When I start out in Drive, it shifts 1,2,3,2, and stays in 2nd, no matter how fast I go. It only stays in 3rd for less than a second. I am thinking maybe a stuck governor. Any other ideas on what I should be looking for? |
| Author: | bigslant6fan [ Sat Feb 25, 2012 11:03 pm ] |
| Post subject: | . |
By all means,do the factory pressure tests first. Did this trans always have this problem,or did it just start one day? Does it work OK in reverse? I agree, it sounds like a governer or valve body problem |
| Author: | Chuck [ Sun Feb 26, 2012 1:18 pm ] |
It just started one day. Works OK in reverse. |
| Author: | WagonsRcool [ Sun Feb 26, 2012 2:52 pm ] |
You need a 300psi pressure guage connected to the pressure test ports on the trans. It could be governor- pressure should increase steadily with vehicle speed. My bet is on a valve body problem. |
