It is currently Tue Nov 17, 2026 8:00 am
 Post subject: Slant 6 manifolds
PostPosted: Sat Feb 25, 2012 2:42 pm
Hi i'm doing my manifolds! I have them split and resurfaced. I ned to re assemble them and instal. Some pieces are missing on the heat riser, the outside springs and bushings, does anyone know of a good source for parts or are the important ? Thanks! Vic 8)
Cudaman, 1965 Cuda, 1967 Coronet 440 1962 Imperial
PostPosted: Sat Feb 25, 2012 8:34 pm
Yes, it's important; the heat valve should be intact and working correctly. Which type do you have, the earlier kind with the small rectangular counterweight, or the later type with the large round one?
PostPosted: Sun Feb 26, 2012 12:34 pm
Well. That's the issue,No counterweight!also the hole for the pivot is worn! Are there part avaiable? Thanks!
PostPosted: Sun Feb 26, 2012 1:46 pm
Sounds like you'd be money, time, and effort ahead to pick a different exhaust manifold to work with.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 4 guests
