| can't find flasher https://slantsix.org/forum/viewtopic.php?t=48037 |
| Author: | Ed Mullen [ Tue Feb 28, 2012 7:19 pm ] |
| Post subject: | can't find flasher |
70 valiant all back together and ready for inspection. We take it for a test drive and the turn signal flasher dies Bought new flasher. Can't find where it goes. Not in, or visible near, fuse block. Not mentioned in FSM. Please help. |
| Author: | DusterIdiot [ Tue Feb 28, 2012 8:12 pm ] |
| Post subject: | under the dash |
It varies by year but generally it's located just above the lip of the dash...in my '67 is had a bracket that held it in place just to the other side of the ashtray...on the late A-bodies ('73 up) it can vary from being near the radio in a similar spot, to being in the mass of spaghetti near the steering column.... Good Hunting, -D.Idiot |
| Author: | Ed Mullen [ Wed Feb 29, 2012 6:48 pm ] |
thanks. found it. I'll need an inspection mirror to figure out how to get it back in the mounting clip. |
| Author: | '74 Sport [ Wed Feb 29, 2012 11:46 pm ] |
Some of the older ones had a square tab molded into the end of the plastic housing. It fit into a small hole in the clip and you twisted the flasher to lock it into place. Don't know about the modern replacement ones. |
