It is currently Wed Nov 11, 2026 9:50 am
 Post subject: Heads
PostPosted: Tue Mar 20, 2012 3:37 pm
Guys
I was wondering if one of the older guys could take me to school on the older head design. Why did they drop the aluminum tube to the spark plug & make the business end of the wire seal it up?
I just got my 63 Plymouth service manual, and am reading up on the special techniques. Like no dechamfering of the cylinder liners.
Thanks.
Slant six should have stayed in production.
PostPosted: Tue Mar 20, 2012 9:42 pm
.....not does not seal tube....tube has o ring to seal it outside /plug inside
PostPosted: Tue Mar 20, 2012 10:55 pm
The wire set I got for it goes onto the plug and has a rubber collar that stops flat at the top of the hole.
O ring?
PostPosted: Tue Mar 20, 2012 11:12 pm
Car Model: 64 Valiant
Post some pics of your wire set.
PostPosted: Tue Mar 20, 2012 11:50 pm
As I understand the the collar on the spark plug wire is just to keep dust and water out. No way is that rubber going to keep your oil in.
Also, without the tube around the plug, your spark plugs and plug wire are going to be covered with hot oil.
Use the tubes on any early slant six.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Wed Mar 21, 2012 5:18 am
Rlklaus : thanks. Kinda what I was thinking
CNC dude: I can't figure out how, I have been on an iPhone for almost a year and so I'd have to get to a working computer and as I understand it or the way it reads the site will only post links to an online album.
Which I don't have. It is a Mopar set from the 70's red wires white box Chrysler pentastar. eBay purchase.
PostPosted: Wed Mar 21, 2012 10:23 am
the tube has oring on bigend seals against outside head....plug seals other end where it goes into head ...no oil around plug.....big flap on wire is just a dust/water cover for plug.....get a service manual
Users browsing this forum: Amazon [Bot] and 5 guests
