It is currently Mon Dec 29, 2025 12:16 pm
PostPosted: Wed Feb 29, 2012 7:46 pm
First timer to this forum, i was ushered over here from vannin i was told you guys are the gurus. Im looking to swap out my 3 spd column tranny from my 72 to a 75 to 87 4 speed manual on the floor, for highway and gas saving purposes. Is there a stock model that would swap right in? i was told there might need to be some modifications to the linkage to get it in a van.
'72 Dodge B200
PostPosted: Wed Feb 29, 2012 8:03 pm
saw the pit`s in other forum. shift on the floor in a van, saw one shifter, looked long not sure if owner welded an exstinsion in the handle. looked cool though.
PostPosted: Thu Mar 01, 2012 7:56 am
did one years ago...had to find the longest shifter and rebend it some as it was installed backwards....facing forward instead of back
PostPosted: Fri Mar 02, 2012 12:17 pm
Car Model: 1977 B100 Van
Yes, I think a833 trans were put in /6 vans from 1975 until 1987, so it should out work pretty well.
I might do the switch myself too.
BTW There's a great thread on the subject on the Mopar B-Van forum.
You should check in, and post and some pics of your van ;)
