| Differential problem https://slantsix.org/forum/viewtopic.php?t=48099 |
| Author: | Jorge89 [ Mon Mar 05, 2012 10:52 am ] |
| Post subject: | Differential problem |
The car is a i965 slant six valiant that was bought in a non running condition due to engine problems.The rearend is off the car.When trying to turn the axles,they have a few degrees play,then it turn freely for aprox 120 degrees,then it tightens up for the rest of the turn.Which should i look for? Parts suppliers?Is ther a place i can send it for repair?Its a 7.25 rearend. Thanks Jorge |
| Author: | Doc [ Mon Mar 05, 2012 11:20 am ] |
Look for chipped or broken spider gears. (pull-off the rear cover and look at the gear teeth) In general, it is best to get a replacement used assembly. Where are you located? DD |
| Author: | Jorge89 [ Mon Mar 05, 2012 7:08 pm ] |
| Post subject: | Differential |
I an at Nashville TN. Thanks Jorge. |
