| Tell me about this cam https://slantsix.org/forum/viewtopic.php?t=48139 |
| Author: | notquiteright [ Fri Mar 09, 2012 4:56 pm ] |
| Post subject: | Tell me about this cam |
About 5yrs ago I bought a new rebuilt short block with a P4286681 cam in it just wondering alittle about the chacteristics of this cam looks like this will finally be the summer I put it in my 71 Dart |
| Author: | Doc [ Fri Mar 09, 2012 5:02 pm ] |
Purple Shaft # P4286681 Cam ID# DC 276-106 Duration 276* Overlap 64* Lift .490 Recomended install 102* Lash int .016 exh .020 The engine's static compression ratio needs to be in the 9.8 - 10 to 1 range for that cam to work well so don't use it in a "stock" engine, with no other changes. DD |
| Author: | notquiteright [ Fri Mar 09, 2012 5:18 pm ] |
The engine is bored .06 and the head was milled if I remember right about .106 but I'm not sure I will be checking the cc's first and it will be alittle while before putting it all together The head was also lightly ported |
