It is currently Tue May 26, 2026 6:57 pm
PostPosted: Fri Mar 09, 2012 9:40 pm
Car Model: 1963 Dodge Dart convertible
Looks like my rear is down a bit but I dont know how to check if the rear is too low or not and if I need to replace the springs.
Can anyone enlighten me on how this check is done?
If its low can I add a extra spring or do I need to replace the entire leaf spring setup?
Thanks Guys!
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Fri Mar 09, 2012 10:20 pm
The rear should be slightly higher than the front. The car's nearly half a century old and almost certainly needs new springs. They're inexpensive enough that it's most cost-effective to install a whole new stack rather than trying to prop up a sagged-out old stack with an extra leaf. Get 5-leaf items from ESPO, www.espo.com . You'll have to call them up; they don't list out the rear springs on their site, but they have them.
PostPosted: Sat Mar 10, 2012 3:12 pm
I second that, my duster was sagging bought a 5leaf set from summit works fine raised the rear of the car a bit.
Kev
PostPosted: Sat Mar 10, 2012 7:11 pm
If you're frugal, you could just lower the front................
:wink:
PostPosted: Sun Mar 11, 2012 11:14 am
thanks to you all! Adding to my list!
PostPosted: Sun Mar 11, 2012 4:55 pm
will the 4door use different springs than a 2door?
cricket
1971 Dodge Dart - 'zippy'
1986 Plymouth Reliant Wagon - 'geraldine'
1994 Honda Civic art car - 'betty'
1972 Honda CL175 - 'roxy'
1986 Honda CL360 ' josie'
PostPosted: Sun Mar 11, 2012 7:09 pm
No difference between 4-door and 2-door. Summit has zero knowledge of A-bodies or springs; they are a sales house. ESPO knows their shìt. Call up and ask for 5-leaf springs for your '63 Dart and you'll be done on the phone in five minutes.
PostPosted: Sun Mar 11, 2012 7:23 pm
If you have an extra main leaf, cut the eyes off and install it as the second leaf in the "stack", doing that will raise the car and if you clamp the front, it will stiffin up the front secions for better torque control.
