| transmission questions https://slantsix.org/forum/viewtopic.php?t=48191 |
| Author: | slantzilla [ Wed Mar 14, 2012 3:48 pm ] |
If it is in fact a '71 trans it will bolt right together. |
| Author: | Reed [ Wed Mar 14, 2012 4:13 pm ] |
Yep. However, now is an ideal time for a fluid and filter change (ATF+4), band adjustment, shift kit install, and verification that it has part throttle kickdown. |
| Author: | Joshie225 [ Wed Mar 14, 2012 5:23 pm ] |
You pulled the trans and engine apart with the torque converter still bolted to the flex plate? So much for the pump bushing and seal. |
| Author: | USAJon [ Wed Mar 14, 2012 5:32 pm ] |
Quote: You pulled the trans and engine apart with the torque converter still bolted to the flex plate? So much for the pump bushing and seal.
dudethis thing slipped off super easy their very light trans was drained ???? |
| Author: | Reed [ Wed Mar 14, 2012 5:42 pm ] |
Quote: how do you adjust the bands?
Get a factory service manual and read the transmission section. It is very easy to do. However, I cannot say if the factory specifications and procedure will work with your aftermarket valve body. A more experienced racer needs to answer that question for you. |
| Author: | WagonsRcool [ Fri Mar 16, 2012 4:15 pm ] |
Also, AFAIK if you have a non-stock ratio (like a 4.2 or 5.0:1) for the kickdown band lever, then you need a different "back the adjuster screw" count from the factory procedure. The service manual gives the basic idea of what to do for a stock trans. |
