| Exhaust manifold quality ? https://slantsix.org/forum/viewtopic.php?t=48212 |
| Author: | lancer61 [ Fri Mar 16, 2012 6:27 am ] |
| Post subject: | Exhaust manifold quality ? |
Have any one here used DORMAN's manifolds (Part # 674232) and know if it's any good ? |
| Author: | SlantSixDan [ Fri Mar 16, 2012 10:16 am ] |
All the aftermarket exhaust manifolds are made in China. Whether they all come from the same factory or not is unknown; it is extremely difficult to chase parts back to their actual origin in China. Dorman is a reputable vendor. Quality of the aftermarket manifolds is generally not quite as good as an original Chrysler manifold, but certainly acceptable. You may have to do a minor amount of grinding to remove casting lines that might interfere with your easy access with a wrench to the studs, nuts, and washers. It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions. |
