| what trans do i have ? https://slantsix.org/forum/viewtopic.php?t=48224 |
| Author: | ratrodster [ Sat Mar 17, 2012 2:30 pm ] |
| Post subject: | what trans do i have ? |
1975 dart swinger slant 6 automatic. how do i verify what trans i have ? thanks ps im very new to mopar |
| Author: | Joshie225 [ Sat Mar 17, 2012 2:36 pm ] |
A904 ![]() Pay attention to the oil pan shape. |
| Author: | Fopar [ Sat Mar 17, 2012 2:47 pm ] |
Or go to this http://www.teufert.net/trans/trannyid.pdf Richard |
| Author: | Slanted Opinion [ Sat Mar 17, 2012 4:20 pm ] |
The A904, like the A727 (used in v8 applications, and on some HD slant six vehicles), is a very tough, very reliable transmission. Treat it well and it should last a long time. - Mac |
| Author: | ratrodster [ Sun Mar 18, 2012 3:37 am ] |
ok, thanks alot guys. for my own interest sake, could i verify this on the vin# or compliance label somewhere on the vehicle ? thanks again |
| Author: | DusterIdiot [ Sun Mar 18, 2012 10:16 am ] |
| Post subject: | Maybe.. |
As long as everything was original to the car, the data tag on the driver's side fender will have a "D" code like D31 that will say the car was optioned that way, physical inspection of the pan shape is the only way to be completely sure though. -D.Idiot |
| Author: | Fopar [ Sun Mar 18, 2012 10:51 am ] |
This web page should give your info (trans ID # stamped on vertical side of pan rail) http://www.mymopar.com/downloads/transguide.pdf Richard |
| Author: | SlantSixDan [ Sun Mar 18, 2012 3:15 pm ] |
The odds are overwhelming that you have an A904 automatic. There is an almost-nonexistent slim chance you have an A727. Check the fender tag, which is on the driver side inner fender. It's a 2" x 3" sheetmetal tag stamped with a bunch of letters and numbers. If you post a clear, sharp photo of it, or an accurate transcript of its contents, we can tell you quite a bit about your vehicle's build and equipment. |
| Author: | ceej [ Wed Mar 21, 2012 7:20 pm ] |
Is something wrong with your transmission? CJ |
