It is currently Wed Dec 31, 2025 6:58 pm
PostPosted: Sun Mar 18, 2012 3:43 pm
Pretty Much what the Subject line of the topic says..
Will the 69 Slant 6 904 Internals swap into a 68 Slant 6 904 case without any fuss or problems?
Thanks 904 Sages!
PostPosted: Sun Mar 18, 2012 3:46 pm
I can't think of any reason why they won't.
PostPosted: Sun Mar 18, 2012 3:51 pm
Thanks Dan - That's what I thought - But you know the dumbest question is the one you didnt ask..
 Post subject: .
PostPosted: Sun Mar 18, 2012 9:07 pm
You'll be fine,the only diference will be the rooster comb and the start/reverce switch. Make sure to check input shaft endplay
PostPosted: Mon Mar 19, 2012 8:07 am
Thanks for the tips Charles.
THe Valvebody will be a 69 piece and THe Switch may be deleted.
If the input shaft endplay is out of spec where may I source Trrust washers?
 Post subject: .
PostPosted: Tue Mar 20, 2012 4:15 pm
The selective thrust washer that corrects endplay is located between the input and output shaft on the 904. A&A transmission is a good source. Don't purchase ones listed for mid 70s-up 904 transmissions,as they are different.
