It is currently Wed Dec 31, 2025 1:40 pm
PostPosted: Thu Mar 15, 2012 9:33 pm
Car Model: 1963 Dodge Dart convertible
Well I keep reading and reading and then my head hurts from all the great information available here.
I am going the route of replacing my 9"drums in the front with disc brakes from a 73, new ball joints etc, but I seem to be having a problem with the best way to get 10" Drums on the rear end.
Can someone suggest the best option for the BBP wheels for the rear end? Do I look for a 8 1/4" or 8 3/4" or find a 7 1/4" with BBP?
I do plan to work the engine some but mild to moderate nothing that radical, just more that stock.
Can you give me some ideas on rear ends and what to expect?
Thanks for the patience for we new folks here, it is greatly appreciated.
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Fri Mar 16, 2012 2:46 am
You could use the rear from the disc brake donor car.
PostPosted: Fri Mar 16, 2012 6:30 am
Would love to but only the disc brake setup is available, ;-(.
Still looking however, there are several available on Seattle CL but so far they are 7 1/4" SBP.
Search continues.
Thanks!
John
PostPosted: Fri Mar 16, 2012 6:38 am
I have another question, I have no idea what to expect on the cost of an 8 3/4" rear end. Can someone give me an idea please?
I see 7 1/4" for $35-$85 and have found a 8 3/4" for $250. At this point from what I have read the 8 3/4" is overkill for my application, mild performance but I am still a novice here but trying to catch up.
Cheers.
PostPosted: Fri Mar 16, 2012 2:58 pm
There is no large bolt pattern 8 3/4 rear the will fit without modifications. The "A" body 8 3/4 is small bolt pattern. If you can find a LPB 7 1/4 in good shape, don't pass on it, if you have a street car. I run a 3.91 SG 7 1/4 in my low 13 sec drag car. Though this is an exceptional case. If you do a search on the site, there are some 8 inch Ford rears that are very close to a "bolt in". Actually easier then using a non "A" body 8 3/4.
PostPosted: Fri Mar 16, 2012 3:21 pm
Contributor
I put aftermarket BBP axles in a 8-3/4 housing. Total cost was around $450.
The price you were quoted for an A-body 8-3/4 is cheap for this part of the country. But, don't forget you will need a driveshaft change if you change rear ends. That was also expensive here.
PostPosted: Fri Mar 16, 2012 5:28 pm
What about a 65-66 B body 8 3/4? I was told they can be bolted in without changing perches in a 72 A body.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Fri Mar 16, 2012 6:09 pm
That rear can be installed by "spreading" the springs. Not really a good idea, as it puts a abnormal side load on the spring bushings and shackles. Also since the rear is wider, you need to find the correct offset wheels, so the tires do not rub the fender.
 Post subject: Pac NW pricing
PostPosted: Fri Mar 16, 2012 6:16 pm
Hit up you local craigslist for prices...
Typically down here in Oregon you are looking at $400-800 for an 8 3/4" depending on ratio/sure grip/modified with axles...
7 1/4" is as cheap as $50 at the local you pull it...most likely it will need some maintenance and is a 2.76 peg leg...
8 1/4" is a mid-range item at $200-500...I picked up the rear under the Hpak duster for $375...8 1/4" out of a '73 340 duster, owner put in a new sure grip unit and new 4.56's...the sure grip was worth about $350 new...he was changing to a Dana 60 and needed some $$ to recoup the costs...
Car-parts.com a year back had an 8 1/4" out of a dart from a yard in Port Orchard for $300 at one time, I think they even listed it as a 3.21 from a 3 speed car.
So FYI, surfing and bargain hunting can be your buddy.
PostPosted: Fri Mar 16, 2012 8:58 pm
15x7 grey spoked Jeep mags. I hear they work with the factory BBP discs.
