| 904 Query? 69 Internals into a 68 Case https://slantsix.org/forum/viewtopic.php?t=48233 |
| Author: | Greg Ondayko [ Sun Mar 18, 2012 3:43 pm ] |
| Post subject: | 904 Query? 69 Internals into a 68 Case |
Pretty Much what the Subject line of the topic says.. Will the 69 Slant 6 904 Internals swap into a 68 Slant 6 904 case without any fuss or problems? Thanks 904 Sages! Greg |
| Author: | SlantSixDan [ Sun Mar 18, 2012 3:46 pm ] |
I can't think of any reason why they won't. |
| Author: | Greg Ondayko [ Sun Mar 18, 2012 3:51 pm ] |
Quote: I can't think of any reason why they won't.
Thanks Dan - That's what I thought - But you know the dumbest question is the one you didnt ask..Greg |
| Author: | bigslant6fan [ Sun Mar 18, 2012 9:07 pm ] |
| Post subject: | . |
You'll be fine,the only diference will be the rooster comb and the start/reverce switch. Make sure to check input shaft endplay |
| Author: | Greg Ondayko [ Mon Mar 19, 2012 8:07 am ] |
Thanks for the tips Charles. THe Valvebody will be a 69 piece and THe Switch may be deleted. If the input shaft endplay is out of spec where may I source Trrust washers? Greg |
| Author: | bigslant6fan [ Tue Mar 20, 2012 4:15 pm ] |
| Post subject: | . |
The selective thrust washer that corrects endplay is located between the input and output shaft on the 904. A&A transmission is a good source. Don't purchase ones listed for mid 70s-up 904 transmissions,as they are different. |
