| Carter AFB J7 9400 S https://slantsix.org/forum/viewtopic.php?t=48234 |
| Author: | Valleyant [ Sun Mar 18, 2012 6:45 pm ] |
| Post subject: | Carter AFB J7 9400 S |
Does anyone know what this 4 barrel carburetor was originally used on? It's a 400 CFM Carter AFB square bore. I am wondering if it would be a good candidate for a Turbo blow through Slant 6 and how much HP it would support? Just need a carb that can make @250-275HP...Any/all help appreciated! |
| Author: | kesteb [ Sun Mar 18, 2012 6:56 pm ] |
A 9400 is an aftermarket performance carburetor not intended for any given engine. It should work just like any other AFB when boosted. |
| Author: | bigslant6fan [ Wed May 16, 2012 6:07 pm ] |
| Post subject: | . |
Two things might be a problem with a blow-through AFB. #1, The hollow brass floats might colapse under boost,I had this problem with a BBD. #2, without an air box around the carb, boost pressure might force raw fuel past the accel pump rod were it goes into the carb. |
