| carb gasket https://slantsix.org/forum/viewtopic.php?t=48251 |
| Author: | oo3 [ Tue Mar 20, 2012 4:40 pm ] |
| Post subject: | carb gasket |
my van came to me with a heat shield installed under carb to manifold - should there be a gasket both between the carb and shield, and shield to manifold - and if so can they both be the fel pro 60085 or should shield to manifold be thinner ? - oo3 |
| Author: | SlantSixDan [ Tue Mar 20, 2012 6:29 pm ] |
Is your heat shield made of sheetmetal or is it the more common gasket-material variety? |
| Author: | oo3 [ Tue Mar 20, 2012 11:58 pm ] |
it is metal - oo3 |
| Author: | SlantSixDan [ Wed Mar 21, 2012 12:03 am ] |
Thick gasket (Fel-Pro 60125 will do) between the heat shield and manifold, thin gasket (60085) between heat shield and carburetor. |
| Author: | oo3 [ Wed Mar 21, 2012 4:13 pm ] |
have a 60085 and ordered a 60125 - thank you - oo3 |
