| lean burn to HEI questions https://slantsix.org/forum/viewtopic.php?t=48294 |
| Author: | Ed Mullen [ Sat Mar 24, 2012 7:49 am ] |
| Post subject: | lean burn to HEI questions |
How is Airtex Wells #6H1013 as a module choice? (Alternate/OEM Part Numbers: 1042820, 1190357, 1875990, 4419628, 592789, 7701021955, 8131941, DR100, J8131941, T1021955) Also, what would be the best 1bbl carb choice for a stock hydro motor van? (I found out that my local carb rebuilder has a pile of 1bbl cores for which he only charges $25 on top of his rebuild fee. I'd have my pick, as 99.9% of his business is 4bbls) I'm looking to keep the purge canister and lose the EGR. I have a distributor already (#3690788). Does anybody know the original application? Without going through the whole re-curve process, are there springs I should switch to right off to make it more van-friendly ? Lastly, is there any 'normal-looking' coil that works well with HEI that I can install in the original location with the OEM type coil to distributor wire? Any advice greatly appreciated. |
| Author: | xjarhead [ Sun Mar 25, 2012 6:10 pm ] |
I running Blaster 2 coil with mine for few years now, no issues. Dave |
