| Break in oil https://slantsix.org/forum/viewtopic.php?t=48313 |
Page 1 of 2 |
| Author: | stolan83 [ Mon Mar 26, 2012 10:42 pm ] |
| Post subject: | Break in oil |
Am going to use Lucas 30w I think it has the zinc and phospheru in it all ready. How long should I run it, 500 miles or what |
| Author: | Joshie225 [ Mon Mar 26, 2012 11:02 pm ] |
Wrong break-in. Brad Penn break-in oil they say to run for 500 miles. |
| Author: | stolan83 [ Mon Mar 26, 2012 11:18 pm ] |
Why that brand? Where can I get it? I am in corona ca , so the web. |
| Author: | Joshie225 [ Mon Mar 26, 2012 11:55 pm ] |
No, not the wrong brand. Wrong word. The brake slows the car. You want to break-in the engine. Brad Penn just happens to make a break-in oil and they say run it 500 miles. |
| Author: | kielbasa [ Tue Mar 27, 2012 12:49 am ] |
Brad Penn is good $#!+ |
| Author: | kielbasa [ Tue Mar 27, 2012 10:16 am ] |
| Author: | SlantSixDan [ Tue Mar 27, 2012 10:41 am ] |
It's a large error to use heavy/thick oil (whatever brand) to break in the engine. You need an extra-light weight of oil for the purpose. |
| Author: | Shaker223 [ Tue Mar 27, 2012 12:28 pm ] |
I used Brad-Penn but changed it out after 100 miles. No issues. |
| Author: | hantayo13 [ Tue Mar 27, 2012 12:53 pm ] |
i run whatever oil i am going to run in engine ...change after cam run in and at 100 & 500 mile |
| Author: | Doc [ Tue Mar 27, 2012 1:56 pm ] |
There are a number of "cam break-in" additives out there... I have been using the stuff from Comp Cams lately. DD
| Author: | DusterIdiot [ Tue Mar 27, 2012 5:24 pm ] |
| Post subject: | Yep... |
Quote: I have been using the stuff from Comp Cams lately.
The local mom and pop places calls this the "secret sauce"...It has moly in it so it's dark in color...I'm a bit put off by the other brand additive that says "zinc" but is clear liquid the viscosity of honey...Last time I worked with some zinc it was grey in color not clear... x2 for comp secret sauce -D.Idiot |
| Author: | Rug_Trucker [ Wed Mar 28, 2012 11:44 am ] |
I bought a couple of cases of STP oil conditioner of some thing like that. It is a 30W with bunches of zinc. Quart sized, not the thick goo in the pints. They quit making it. I always run an engine 20-30 minutes for cam break in then drain, new filter and refill. 10-30 Rotella diesel oil will have all the zinc you need. Don't get the synthetic blend. Not until the engine is broke in. |
| Author: | stolan83 [ Fri Mar 30, 2012 7:12 am ] |
OK, now I am really confused. So what some of you are saying is that the zinc and phosphrus thing is a bunch of marking to sell a more expensive oil and that I should just run normal 30w. THE other half is telling me to us a " on " break in oil. Here is the thing in I am using my existing cam, for not so loved Clifford, So I have all ready broke or ran in the cam and lifters I am mainly worried about setting the rings and reducing blow by. And also I know that I can not spell you dont need to point it out lol. THanks |
| Author: | 69a100 [ Fri Mar 30, 2012 8:27 am ] |
Quote: And also I know that I can not spell you dont need to point it out lol. THanks
When you reply, see that block in the bottom right hand corner that says "spellcheck"??? It will help to show that you have some intelligence and not a hill jack. Just sayin.
| Author: | SlantSixDan [ Fri Mar 30, 2012 8:59 am ] |
Quote: OK, now I am really confused. So what some of you are saying is that the zinc and phosphrus thing is a bunch of marking to sell a more expensive oil and that I should just run normal 30w.
When I read this thread, I don't see what you seem to think you see. Perhaps you should read the thread more carefully.
| Page 1 of 2 | All times are UTC-07:00 |
